Hi.
I were looking at the PR33-36 to measure CR/conductivity in a 7500m 40mm2 cable.
Can this be used to convert resistive measurement to a decimal value?
Or is there another card better suited.
I am going to use a raspberry pi and a 4-20 mA card as well as a temp sensor to measure ambient temperature.
the board is designed to read upto 20V, you should be fine if you want to read voltage within the range.
yes, the board will convert voltage into digital values.
Thank you for your reply. Is the circuit board able to read continuity? Low Ohm value via the adc input based on a set voltage (5-20vdc) based on the voltage drop calculation), on a 20 or 40 mm2 7500m copper cable.
