Hi community, can someone tell me what the “counter” data point represents?
Thanks!
Nirat
Thanks!
Nirat
Hi @nirat.keswani Sure, this is a simple packet counter. It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets
The sensor increments this value each time it sends sensor data. It has a range from 0 to 255, meaning that when the counter reaches 255, it resets to 0.
The value is set to 0 when the sensor is powered on for the first time and sends its first packet. It also resets to one when the sensor is manually reset by pressing the button or by turning the sensor off and on again
Thank you.
