I have multiple 24-Channel DPDT Signal Relay Controller + 8 GPIO with I2C Interface boards and use the same python code for all. I commissioned a new relay board today, same as mentioneed above, however I cannot recognize the adresses as with the others. I issue the command, i2cdetect -y 1 and receive a blank matrix in return.
the cuyrrent boards responds with:
pi@raspberrypi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: – -- – -- – -- – -- – -- – -- – --
30: – -- – -- – -- – -- – -- – -- – -- – --
40: – -- – -- – -- – -- – -- – -- – -- – --
50: – -- – -- – -- – -- – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
All the other boards respond with the the following:
20: 20 21 – -- – -- – -- – -- – -- – -- – --
Can you direct on what the issue may be, there are no jumpers in place
