Hello admin,
I’ve uploaded the files to the mentioned directory in the pi but it seems a little error in the script.js because it cant find a way to interface with HTML file and not displaying the values in the Webpage it default showing "Loading ", When I entered the Ip of pi… help me out with the javascript
Here is the code I’ve used:
window.onload=function(){
fetchValues(valuesCallback);
function fetchValues(callback){
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (xhttp.readyState == 4 && xhttp.status == 200) {
callback(JSON.parse(xhttp.responseText));
xhttp.open("GET", "/CurrentMonitor.py", false);
xhttp.send();
return;
function valuesCallback(results){
var output = "<table><thead><th>Channel</th><th>Reading</th></thead><tbody>";
for(var i=0;i<results.length;i++){
output+="<tr><td>Channel "+(i+1)+":</td><td>"+results[i]+"</td></tr>";
output+='</tbody></table>';
document.getElementById('results').innerHTML = output;
document.getElementById('header').innerText = 'Current Readings';
window.setTimeout(function(){fetchValues(valuesCallback);}, 2000);
