Hi, I bought 2 AMS5915-0010-D sensors.
With the same coding, I got 2 different reading from the sensors.
First sensor is around 0-1Pascal, while the other sensor is around 4988Pascal.
May I know is it the hardware problem or coding problem?
Following is my coding.
AMS5915_example.ino
Brian R Taylor
brian.taylor@bolderflight.com
Copyright © 2017 Bolder Flight Systems
Permission is hereby granted, free of charge, to any person obtaining a copy of this software
and associated documentation files (the “Software”), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute,
sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or
substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING
BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include “AMS5915.h”
// an AMS5915 object, which is a
// static pressure sensure at I2C
// address of 0x12, on I2C bus 0,
// and is a AMS5915-1200-B
AMS5915 sPress(Wire,0x28,AMS5915::AMS5915_0010_D);
void setup() {
// serial to display data
Serial.begin(9600);
while(!Serial){}
// starting communication with the
// static pressure transducer
if (sPress.begin() < 0) {
Serial.println(“Error communicating with sensor, check wiring and I2C address”);
while(1){}
void loop() {
// read the sensor
sPress.readSensor();
// displaying the data
float pa = sPress.getPressure_Pa();
Serial.print(pa,6);
Serial.print("\t");
Serial.println(sPress.getTemperature_C(),6);
delay(500);
Thank you.
Kai
