We’ve been developing with the 16-BIt 2-Channel 4-20mA Current Loop Receiver.
Love the fact that it has enough voltage to run some of our sensors now.
I can see its transmissions via Alpha station, on a Windows PC with 900mhz modem hooked up.
However, I am not getting a payload via the MQTT Micro Gateway
I still see other sensors, like vib temp, 1 channel 4-20 sensors, but not this 2 channel 4-20ma.
From the Alpha Station patch notes, I think it was only added recently.
How soon does it get added to the firmware for the MQTT Micro Gateway?
(I did try flashing the Gateway, and still no luck in receiving the transmission from the 16-Bit 2-Channel 4-20mA)
I just updated the MQTT firmware on our cloud repository to 1.0.3 and it should now support that device. Please flash the firmware again and let me know if you have any trouble.
Thanks Travis, that worked, the gateway sees the 4-20ma 2Channel now.
The value reported on mA_1 looks a bit high. The setup is an ultrasonic 4-20mA sensor sitting on my desk, with no vibration.
It shows the same as in Alpha station. Mark is going to take another look at it to make sure we have it wired up correctly.
