Hi there,
I’d like to change the counting threshold of NCD 1-channel counter via configuration mode. In the configuration commands table (table-4), I don’t see anything related to the counting threshold. Any idea how I can change the counting threshold?
Thanks.
Hi, The command looks like this
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F4 0100 0023 0000 000A D2
“payload F4 01 00 00 23 00 00 00 0A”
In the above command I am setting the counter threshold value to 10.
We also updated the UI which can be used to set the threshold and also to extract the command
Thanks, it worked. the “23” in the payload command is the sensor_type?
yup… thats the sensor type… its an optional thing. it will work without it
