EEProm read was the only way I could get it to work; docs probably need updating?
Working node-red flow to get current values from a 0-10V endnode:
[{"id":"49309f71.766f6","type":"tab","label":"ASM1-5 0-10V Read","disabled":false,"info":""},{"id":"7937084d.f023b8","type":"ncd-gateway-node","z":"49309f71.766f6","name":"Gateway","connection":"3a674906.5b9e76","unknown_devices":true,"outputs":2,"x":668,"y":108,"wires":[["aaf672d.c4cfc9"],["e7d5726d.b13aa","aaf672d.c4cfc9"]]},{"id":"c8408ef2.58339","type":"function","z":"49309f71.766f6","name":"Read All 0-10V Controllers","func":"msg.payload = {};\nmsg.payload.data = [0xfe,0x34,0x1d,0xb0,0x10];\nmsg.payload.address = \"00:00:00:00:00:00:FF:FF\"; // broadcast\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":382,"y":105,"wires":[["e2971ca2.3e749"]]},{"id":"e7d5726d.b13aa","type":"function","z":"49309f71.766f6","name":"Is Return?","func":"// only continue if this is a 16 bit response\nif (msg.payload.data.length != 19)\n return null\nif (msg.payload.data[0] != 0xaa || msg.payload.data[1] != 0x10)\n return null;\n \n// compose the result msg\nmsg.payload.addr = msg.payload.addr;\nmsg.payload.sensor_data = {};\nmsg.payload.sensor_data.pr53_14_Output_1 = (msg.payload.data[2] * 256) + msg.payload.data[3];\nmsg.payload.sensor_data.pr53_14_Output_2 = (msg.payload.data[4] * 256) + msg.payload.data[5];\nmsg.payload.sensor_data.pr53_14_Output_3 = (msg.payload.data[6] * 256) + msg.payload.data[7];\nmsg.payload.sensor_data.pr53_14_Output_4 = (msg.payload.data[8] * 256) + msg.payload.data[9];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":709.5,"y":199,"wires":[["aaf672d.c4cfc9"]]},{"id":"aaf672d.c4cfc9","type":"debug","z":"49309f71.766f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950.5,"y":202,"wires":[]},{"id":"7d44e897.142798","type":"inject","z":"49309f71.766f6","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":121.5,"y":107,"wires":[["c8408ef2.58339"]]},{"id":"e2971ca2.3e749","type":"function","z":"49309f71.766f6","name":"doNcdEncode","func":"var command = msg.payload.data;\ncommand.unshift(0xAA, command.length);\nvar sum = 0x00;\nfor(i = 0; i < command.length; i++){\n sum+=command[i];\n}\ncommand.push(sum&0xFF);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":412,"y":204,"wires":[["7937084d.f023b8"]]},{"id":"3a674906.5b9e76","type":"ncd-gateway-config","name":"","comm_type":"serial","ip_address":"","tcp_port":"2101","port":"/dev/ttyS1","baudRate":"115200","pan_id":"7FFF","rssi":false}]
edit: a few improvements to the output if anyone cares:
[{"id":"49309f71.766f6","type":"tab","label":"ASM1-5 0-10V Read","disabled":false,"info":""},{"id":"7937084d.f023b8","type":"ncd-gateway-node","z":"49309f71.766f6","name":"Gateway","connection":"3a674906.5b9e76","unknown_devices":true,"outputs":2,"x":634.0000190734863,"y":106.00000381469727,"wires":[[],["e7d5726d.b13aa"]]},{"id":"c8408ef2.58339","type":"function","z":"49309f71.766f6","name":"Broadcast for 0-10V Controller data","func":"msg.payload = {};\nmsg.payload.data = [0xfe,0x34,0x1d,0xb0,0x10];\nmsg.payload.address = \"00:00:00:00:00:00:FF:FF\"; // broadcast\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":343.00000762939453,"y":107.00000381469727,"wires":[["e2971ca2.3e749"]]},{"id":"e7d5726d.b13aa","type":"function","z":"49309f71.766f6","name":"decodeASM5-1","func":"var getFriendlyFromOutput = function(state) {\n var percent;\n if (state == 0)\n percent = 0;\n else\n percent = state * 103.99 / 4095;\n \n if (percent > 90) {\n return \"ON\";\n } else if (percent < 30) {\n return \"OFF\";\n } else {\n return Math.round(percent) + \"%\";\n }\n}\n\nvar getPercentFromOutput = function(state) {\n var percent;\n if (state == 0)\n percent = 0;\n else\n percent = state * 103.99 / 4095;\n \n return Math.round(percent);\n}\n \n\n// only continue if this is a 16 bit response (fram read)\nif (msg.payload.data.length != 19 ||\n msg.payload.data[0] != 0xaa || \n msg.payload.data[1] != 0x10\n)\n return null;\n \n// compose the result msg\nmsg.payload.addr = msg.payload.addr;\nmsg.payload.sensor_data = {};\nmsg.payload.sensor_data.pr53_14_Raw_1 = (msg.payload.data[2] * 256) + msg.payload.data[3];\nmsg.payload.sensor_data.pr53_14_Raw_2 = (msg.payload.data[4] * 256) + msg.payload.data[5];\nmsg.payload.sensor_data.pr53_14_Raw_3 = (msg.payload.data[6] * 256) + msg.payload.data[7];\nmsg.payload.sensor_data.pr53_14_Raw_4 = (msg.payload.data[8] * 256) + msg.payload.data[9];\n\nmsg.payload.sensor_data.pr53_14_Voltage_1 = msg.payload.sensor_data.pr53_14_Raw_1 * (10.3992 / 4095);\nmsg.payload.sensor_data.pr53_14_Voltage_2 = msg.payload.sensor_data.pr53_14_Raw_2 * (10.3992 / 4095);\nmsg.payload.sensor_data.pr53_14_Voltage_3 = msg.payload.sensor_data.pr53_14_Raw_3 * (10.3992 / 4095);\nmsg.payload.sensor_data.pr53_14_Voltage_4 = msg.payload.sensor_data.pr53_14_Raw_4 * (10.3992 / 4095);\n\nmsg.payload.sensor_data.pr53_14_Percent_1 = getPercentFromOutput(msg.payload.sensor_data.pr53_14_Raw_1);\nmsg.payload.sensor_data.pr53_14_Percent_2 = getPercentFromOutput(msg.payload.sensor_data.pr53_14_Raw_2);\nmsg.payload.sensor_data.pr53_14_Percent_3 = getPercentFromOutput(msg.payload.sensor_data.pr53_14_Raw_3);\nmsg.payload.sensor_data.pr53_14_Percent_4 = getPercentFromOutput(msg.payload.sensor_data.pr53_14_Raw_4);\n\nmsg.payload.sensor_data.pr53_14_Friendly_1 = getFriendlyFromOutput(msg.payload.sensor_data.pr53_14_Raw_1);\nmsg.payload.sensor_data.pr53_14_Friendly_2 = getFriendlyFromOutput(msg.payload.sensor_data.pr53_14_Raw_2);\nmsg.payload.sensor_data.pr53_14_Friendly_3 = getFriendlyFromOutput(msg.payload.sensor_data.pr53_14_Raw_3);\nmsg.payload.sensor_data.pr53_14_Friendly_4 = getFriendlyFromOutput(msg.payload.sensor_data.pr53_14_Raw_4);\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":651.5000190734863,"y":179.0000057220459,"wires":[["aaf672d.c4cfc9"]]},{"id":"aaf672d.c4cfc9","type":"debug","z":"49309f71.766f6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":867.5000267028809,"y":179.0000057220459,"wires":[]},{"id":"7d44e897.142798","type":"inject","z":"49309f71.766f6","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":121.5,"y":107,"wires":[["c8408ef2.58339"]]},{"id":"e2971ca2.3e749","type":"function","z":"49309f71.766f6","name":"doNcdEncode","func":"var command = msg.payload.data;\ncommand.unshift(0xAA, command.length);\nvar sum = 0x00;\nfor(i = 0; i < command.length; i++){\n sum+=command[i];\n}\ncommand.push(sum&0xFF);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":400.00001525878906,"y":180.0000057220459,"wires":[["7937084d.f023b8"]]},{"id":"3a674906.5b9e76","type":"ncd-gateway-config","name":"","comm_type":"serial","ip_address":"","tcp_port":"2101","port":"/dev/ttyS1","baudRate":"115200","pan_id":"7FFF","rssi":false}]
